Ошибка #999 на газовом хроматографе Agilent 7890 A >>>
  Ответов в этой теме: 1
Автор Тема: Ошибка #999 на газовом хроматографе Agilent 7890 A
Я.О.В.
Ранг: 13
31.05.2011 // 13:25:38
Помогите пожалуйста! При запуске online и offline выдается ошибка #999?
Serga
Ранг: 1806
31.05.2011 // 13:43:20
Autostart Macro failed, error# 999 occurred (Rev. B.03.0x)
Service Serial Numbers:
The Autostart Macro failed, error# 999 occurs on startup of the Chemstation if
the Initial Screen Window Size is set to “Icon” in the Configuration editor.
In the PCS section of the ChemStation.ini, the WinSize setting will be
specified
as WinSize=Min.
Parts Required:
None
Situation:
The Initial Screen Window Size can be changed randomly if the Initial Screen
Window Size is set to Normal and then the Chemstation is closed when iconized
in the taskbar. The Chemstation.ini will have the WinSize value = Min and when
the Chemstation is started, the error occurs. If the Chemstation is closed
when the ChemStation window is maximized, then the WinSize key will be
set to Normal and no errors occur on start up.
So, if the ChemStation is iconized to the taskbar and the user right-clicks on
the icon to close the chemstation, the autostart Macro Failed, error# 999 will
occur when starting the Chemstation.
Solution/Action:
In Chemstation.ini, if the WinSize value = Min, change the value to Normal
before starting the Chemstation.
[PCS,1]
InstType=gcoffline
InstName=Instrument 1
WinSize=Normal
Use the Configuration Editor to set the Initial Screen Window Size to Normal.
Additional Information:
G2070BA PVCS Defect No. 1042.
Скачать это же в виде Service Note G2070BA-011 можно отсюда:
www.chem.agilent.com/Library/Support/Documents/f396374470.pdf
