JPVIII на Таурин (Taurine) >>>
  Ответов в этой теме: 5
Автор Тема: JPVIII на Таурин (Taurine)
biotranzit
Ранг: 13
15.08.2005 // 18:41:10
У кого есть статья из JP VIII на Таурин (Taurine)?
Подмогите статьей из Японской фрмакопеи 8 издание на Таурин. Можно и на японском.
Garry
Ранг: 1076
16.08.2005 // 10:07:27
У меня есть Японская фармакопея JP XIV 2004, но там о таурине ни слова.
Artem
Ранг: 193
16.08.2005 // 11:17:05
Таурин есть в фармакопее Америки (по крайней мере 27 издания). Смотрите, если очень нужно. Вот эта статья:
Taurine
C2H 7NO 3S 125.15
Taurine [107-35-7].
» Taurine contains not less than 98.5 percent and not more than 101.5
percent of C2H7NO3S, calculated on the dried basis.
Packaging and storage— Preserve in well-closed containers.
USP Reference standards б 11 с — USP Taurine RS.
Identification, Infrared Absorption б 197K с .
Loss on drying б 731 с — Dry it at 105° for 3 hours: it loses not more than 0.3% of its weight.
Residue on ignition б 281 с : not more than 0.3%.
Chloride б 221 с — A 0.7-g portion shows no more chloride than corresponds to 0.50 mL of
0.020 N hydrochloric acid. Not more than 0.05% is found.
Sulfate б 221 с — A 0.8-g portion shows no more sulfate than corresponds to 0.25 mL of 0.020
N sulfuric acid. Not more than 0.03% is found.
Iron б 241 с : 0.003%.
Heavy metals, Method I б 231 с : 0.0015%.
Chromatographic purity—
Adsorbent: 0.25-mm layer of chromatographic silica gel mixture.
Test solution— Dissolve an accurately weighed quantity of Taurine with water to obtain a
solution having a concentration of about 10 mg per mL.
Standard solution— Dissolve an accurately weighed quantity of USP Taurine RS with water to
obtain a solution having a known concentration of about 0.05 mg per mL, equivalent
concentration to about 0.5% of the Test solution.
Application volume: 5 µL.
Developing solvent system: a mixture of butyl alcohol, glacial acetic acid, and water (60:20:20).
Spray reagent— Dissolve 0.2 g ninhydrin in 100 mL of a mixture of butyl alcohol and 2 N acetic
acid (95:5).
Procedure— Proceed as directed for Thin-Layer Chromatography under Chromatography б
621 с, except to dry the plate at 80° for 30 minutes. Spray the plate with Spray reagent, and
heat at 80° for about 10 minutes. Examine the plate under white light: no secondary spot in the
chromatogram of the Test solution is larger or more intense than the principal spot in the
chromatogram of the Standard solution. Not more than 0.5% of individual impurities are found.
[Note —The R F value for the taurine spots should be about 0.2.]
Organic volatile impurities, Method I б 467 с : meets the requirements.
Assay— Proceed as directed for Method II under Nitrogen Determination б 461 с. Each mL of
0.01 N sulfuric acid is equivalent to 1.25 mg of C 2H 7NO 3S.
Auxiliary Information—
Staff Liaison : Lawrence Evans, Ph.D., Senior Scientific Associate
Expert Committee : (DSN) Dietary Supplements: Non-Botanicals
USP27–NF22 Page 1766
Pharmacopeial Forum : Volume No. 27(6) Page 3331
Phone Number : 1-301-816-8389
biotranzit
Ранг: 13
16.08.2005 // 13:31:43
Всем большое спасибо!
Да, верно, в 14 издании JP о нем нет инфы.
Просто материал стандартизирован производителем именно по JP VIII.
Вот и хотелось бы узнать, в чем фишка и разница..
А Юиспишку 27 где покупали, на какой территории? Махну на Британскую 2000 года на CD или на USP26 на CD. Если есть интерес напишите: pb8427[собака]solo.by
КонстантинС
Ранг: 2306
18.08.2005 // 23:58:26
Вот ведь ХИЛИК как ХИЛИК! Прямо почти в стиле Леонида!
Помню, однажды я хулиганил в детстве - тоже 20% кислоты добавлял, но не уксусной, а триметилуксусной (т.к. только она в таких количествах растворялась в гексане). И был элюент гексан-триметилуксусная 80-20, силикагель, фенолы. Между прочим, очень были интересные результаты! Но я это дело быстро забросил - надоело, да и кислота эта плохо пахнет...
Artem
Ранг: 193
22.08.2005 // 14:14:23
biotranzit пишет:
Юиспишку 27 достали по случаю. Мне нужна очень была, так как сам занимаюсь фарманализом. 26-ю мне обещали. Скоро передадут.
А Европа 5-я у вас есть? могу поделиться.
