Ионные растворы >>>
  Ответов в этой теме: 6
Автор Тема: Ионные растворы
Nowhereman42nd
Ранг: 154
23.10.2019 // 14:17:54
Добрый день!
Есть ли на форуме специалисты по ионным растворам? Или хотя бы те люди, которые писали бакалаврскую/магистерскую работу по ним?
Просто я создаю новую теорию термодинамики ионных растворов (новую - в том плане, что нигде такой не видал ещё), но подозреваю, что она ни разу не новая (потому что кто-нибудь уже давным давно проделал мою работу).
Valerа1234
Ранг: 2884
23.10.2019 // 16:04:33
Thermodynamics of Ions in Solutions
Chapter · December 2017 with 93 Reads 
DOI: 10.1016/B978-0-12-409547-2.13600-5
In book: Reference Module in Chemistry, Molecular Sciences and Chemical Engineering
Cite this publication
Ilya Pobelov
32.95Universität Bern
Abstract
This article treats application of basic thermodynamic concepts to ions in electrolyte solutions. The discussion is focused on the properties of single ions, as opposed to the mean properties of electrolytes; furthermore, the material is presented in historical prospective. Connections to classical and chemical thermodynamics as well as to the theory of electromagnetism are emphasized. After the introduction of the electrochemical potential for charged particles, the real and chemical energy of solvation, a concept somewhat similar to electron work function in metals, are critically discussed. It is concluded that the real (including surface potential) energy of solvation for individual ions can be obtained experimentally in a thermodynamically correct process, while the chemical energy of solvation can be only estimated by involving certain theoretical extra-thermodynamic assumptions. The real energy of solvation obtained for a range of solutions can be in principle used to calculate its standard value, provided that the scale of activity is established for single ions. The historical development of single ion activity (SIA) concept and experiments aimed at determining the SIA is described further. It is concluded that the SIA is a useful concept that should not be disregarded. At the same time there appears to be no experimental tool that allows the determination of single ion activities in a strictly thermodynamically correct procedure, as all experimental procedures proposed to date employ some kind of an extra-thermodynamic assumption. The validity of such assumptions and of the experiments aiming at determining SIA remains debatable. Finally, the Debye–Hückel theory was considered and it was concluded that the Debye–Hückel limiting law is the only universally recognized tool providing information about the thermodynamic properties of individual ions in solution.
https://chem.libretexts.org/Bookshelves/General_Chemistry/Book%3A_Chem1_(Lower)/08%3A_Solution_Chemistry/8.2%3A_Thermodynamics_of_Solutions
Nowhereman42nd
Ранг: 154
23.10.2019 // 16:12:23
Valerа1234 пишет:
предельный закон Дебая – Хюккеля
Похоже, что речь идёт о ионно-молекулярных растворах, но меня интересуют именно ионные - в которых нет ни молекул воды, ни каких либо других - чисто одни ионы. Такое бывает в расплавах солей.
Но статья, думаю, очень интересная. Я полагал, что самая лучшая теория для ионно-молекулярных растворов на данный момент - это модель Питцера (о существовании которой знаю только от давно умершего преподавателя).
Nowhereman42nd
Ранг: 154
25.10.2019 // 8:42:34
А вообще очень интересно, что теорию Дебая-Хюккеля для ионно-молекулярных растворов до сих пор считают чем-то убер-современным. По мне, это как если физику Аристотеля считать современной. Значит, есть шанс, что в области чисто ионных растворов до сих пор творится такой бардак (с года где-то 1994го), и у моей работы есть все шансы на актуальность.
vmu
Ранг: 1428
26.10.2019 // 9:59:18
В последние годы популярна тема ионных жидкостей (ionic liquids). Попробуйте поискать по этим ключевым словам.
Nowhereman42nd
Ранг: 154
29.10.2019 // 7:25:56
vmu пишет:
Несомненно, тема очень интересная. Но моя теория работает с простыми неорганическими ионами, а не с органическими гигантами. И область применимости - более 100 С. При низких температурах теория может забуксовать и в силу некоторых причин труднопроверяема. Особенно если в системе присутствуют такие тугоплавкие соединения как CaO - там вообще только при высоких температурах теория будет работать.
ЦветХром ЦветХром
ООО «ЦветХром» производит лабораторные и промышленные генераторы водорода, деонизатор воды, систему очистки воздуха Поток-01, микрошприцы Стандарт. А также производит оборудование для модернизации старого парка хроматографов (БУС-02 для Цвет 500, АЦП АПК-02 + программа ЦветХром). Производит лабораторную мебель. Поставляет оборудование жидкостной хроматографии.
Nowhereman42nd
Ранг: 154
31.10.2019 // 20:32:19
Позвольте поделиться ссылкой на тему ионных растворов
https://otvet.mail.ru/question/197108682
При прочтении соблюдайте осторожность: лицо потом будет болеть от ударов ладонью.
