graphite rings are a ring-shaped >>>
  Ответов в этой теме: 0
Автор Тема: graphite rings are a ring-shaped
adtech
27.04.2022 // 5:25:52
Name: Reinforced <a href="www.adtechamm.com/aluminum-degassing-units/" target="_blank">degassing unit</a><br />
<br />
<br />
Features:<br />
<br />
The reinforced <a href="www.adtechamm.com/aluminum-degassing-units/" target="_blank">degassing units</a><br />
are a ring-shaped graphite packing formed by adding metal materials such as 304 steel belt, steel wire mesh, nickel wire mesh, etc. to the inside of the expanded graphite packing ring, and then pressed by a mold. In order to improve the compression resistance of the graphite ring, it is generally used in high temperature and high pressure sealing.<br />
<br />
1. Good self-lubrication<br />
<br />
2. High rebound coefficient<br />
<br />
3. Suitable for use under high temperature and high pressure conditions.<br />
<br />
equipment:<br />
<br />
Valves, pumps, etc.<br />
<br />
industry:<br />
<br />
Recommended for petroleum equipment, power plants, chemicals, steel mills, etc.<br />
<br />
medium:<br />
<br />
Except for a few strong oxidizing media, it can be used to seal hot water, high temperature, high pressure steam, heat exchange media, hydrogen, ammonia, organic solvents, hydrocarbons, low temperature liquids and other media<br />
<br />
Product specifications: Φ5mm--Φ1000mm; special specifications or various non-standard products can be made according to customer requirements
