Энантиоселективная хроматография >>>
| Автор | Тема: Энантиоселективная хроматография |
Ру Пользователь Ранг: 6 |
Как разделить энантиомеры этил-3-гидроксибутирата на энантиоселективной колонке? Какой режим подобрать? |
vmu Пользователь Ранг: 1416 |
Редактировано 1 раз(а) Separation of Enantiomers of Ethyl 3-Hydroxybutyrate by HPLC with Chiral Chromatographic Column A method of HPLC was proposed for the resolution of enantiomers of ethyl 3-hydroxybutyrate using Chiralcel OD-H chiral column (4.6 mm × 250 mm, 5 μm) for separation. A mixture of n-hexane and isopropyl alcohol (100 + 5) was used as mobile phase with flow-rate of 1.0 mL/min. Column temperature of 25 ℃ was chosen. Under the optimized conditions, enantiomers of ethyl 3-hydroxybutyrate were successfully separated within 11 min, with resolution of 4.25. |
Ответов в этой теме: 1 |
