Thermal Desorption-Gas Chromatography–Mass Spectrometry (TD-GC–MS) >>>
  Ответов в этой теме: 18
Автор Тема: Thermal Desorption-Gas Chromatography–Mass Spectrometry (TD-GC–MS)
ident
Ранг: 160
18.09.2006 // 20:24:40
Уважаемые форумчане!
Просветите, пожалуйста, в ситуации.
1. Есть прибор, означенный как «Thermal Desorption-Gas Chromatography–Mass Spectrometry (TD-GC–MS)».
Если можно, объясните, что это означает (тип, марка, производитель,….)
2. Есть концентрации веществ, которые он (как заявлено) определяет (сокращения и аббревиатуры не мои):
1-Heptene
1-Heptene, 5-methyl
1-Hexanol, 2-ethyl
1-Hexene
1-H-indene, 2,3-dihydro
1-H-indene, 2,3-dihydro-2-methyl
1-Pentene, 2-methyl
1-Pentene, 3-ethyl
1-Propene
2-Beta-pinene
2-Butanone
2-Hexanone
2-Octene
2-Pentanone
2-Pentene, 4-methyl
3-Pentanone
Acetaldeheyde
Acetic acid, ethyl ester
Acetic acid, methyl ester
Acetic acid, propyl ester
Acetone
Alpha-pinene
Benzene
Benzene-(1-methylethenyl)
Benzene, (2-methyl-1-propenyl)
Benzene, 1,2,3-trimethyl
Benzene, 1,2,4-trimethyl
Benzene, 1,3-diethenyl
Benzene, 1-ethenyl-4-ethyl
Benzene, 1-ethyl-2-methyl
Benzene, 1-ethyl-3-methyl
Benzene, 1-ethyl-4-methyl
Benzene, ethyl
Benzene, propyl
Butane, 2,2,3-trimethyl
Butane, 2,3-dimethyl
Butanoic acid, ethyl ester
Carbon disulfide
Carbon oxide sulfide
Carbonic acid, dimethyl ester
Cyclohexane, 1,2,4-trimethyl(1-alpha)
Cyclohexane, 1,3-dimethyl
Cyclohexane, 1,4-dimethyl
Cyclohexane, 1-ethyl-4-methyl
Cyclohexane, methyl
Cyclohexanone
Decanal
Decane
Dichloromethane
di-Limonene
Disulfide, dimethyl
Disulfide, methyl ethyl
Ethanol
Ethanone, 1-phenyl
Gamma-terpinene
Heptane
Heptane, 2,4-dimethyl
Heptane, 2-methyl
Heptane, 3-methyl
Heptane, 4-methyl
Hexanal
Hexane
Hexane, 2,3-dimethyl
Hexane, 2-methyl
Hexane, 3-methyl
Isoprene
Methane, chloro
Methane, chlorodifluoro
m-Xylene
Napthalene
n-Octyl acetate
Nonanal
Nonane
Octane
Octane, 3-methyl
o-Xylene
Pentane
Pentane, 2,3,3-trimethyl
Pentane, 2,3,4-trimethyl
Pentane, 2,4-dimethyl
Pentane, 2-methyl
Pentane, 3-methyl
Phenol
Propane, 2-ethoxy-2-methyl
p-Xylene
Styrene
Tetrachloromethane
Toluene
Trisulfide, dimethyl
Undecane
3. Прошу любые пояснения к данной информации.
Заранее спасибо тем, кто откликнется!
19.09.2006 // 8:57:09
Указанный прибор представляет собой хромато-масс-спектрометр (т.е. хроматограф с масс-спектрометром в качестве детектора), снабженный приставкой для термодесорбции.
Эта приставка позволяет накапливать на специальном патроне с сорбентом органические вещества из воздуха а потом десорбировать их при нагреве в хроматограф. Это позволяет на порядки поднять чувствительность определения. Наиболее известна производством таких систем фирма Перкин Элмер. Стоит это удовольствие от 90 до 160 килобаксов, в зависимости от комплектации.
Представленный перечень веществ является типичным набором при загрязнении воздуха парами нефтепродуктов или растворителей, поскольку там представлен практически весь набор летучих углеводородов и сопутствующих им веществ.
А всвязи с чем интерес к этой теме?
19.09.2006 // 9:44:45
И еще. Если интересует конкретная марка прибора, то у меня тут под рукой оказался проспект Перкин Элмера.
В принципе это может быть Clarus 500MS с термодесорбционной приставкой Turbomatrix ATD или TD. Хотя наверняка аналогичные приборы делает и Аджилент, а также другие фирмы.
И кроме перечисленных веществ в зависимости от используемой колонки или их комбинации, такая система может на следовом уровне определять еще эдак тысяч семдесят - сто веществ.
ident
Ранг: 160
19.09.2006 // 10:13:44
2Леонид.
Спасибо большое за быстрый ответ. Интерес к этим приборам связан с тем, что в настоящее время с одной греческой фирмой идет интенсивный обмен информацией, экспериментальными данными и предварительными результатами расчетов в направлении создания подхода к определению наличия живых людей под завалами зданий после землетрясений. Речь идет о разделении полученной информации о живых людях, трупах и других "вложений".
Собственно, к этой работе я подключился, когда уже были наработаны первые данные именно на этой серии приборов.
Если можно, еще вопрос. Насколько громоздки эти приборы и насколько длительный по времени процесс анализа данных?
19.09.2006 // 10:37:20
Вообще то это достаточно немаленькие приборы.
Полный комплект указанного мной типа приборов займет место на столе как двухкамерный холодильник, положенный на бок. Да и энергопотребление составит около 4 КВт.
Если использовать даже короткие (до 30 м) и тонкие (0,1 мм) капиллярные колонки, то и в этом случае хроматограмма будет сниматься минут 20-25.
Существуют, правда, и портативные хромато-масс-спектрометры и хроматографы. На некоторые из них давал ссылку Islander в теме "Портативные газовые хроматографы".
www.anchem.ru/forum/read.asp?id=2631&recordnum=10
Но их возможности, пожалуй, просто не позволят разделить за один проход весь спектр представленных Вами соединений.
Или, может быть, такая задача не стоит?
ident
Ранг: 160
19.09.2006 // 12:58:33
2Леонид.
Как раз в ближайшее время жду информацию по принципу выбора приборов и возможностей использования альтернативных вариантов.
БиоХимМак БиоХимМак
Оснащение научных и медико-диагностических лабораторий.
EX-Mnemonick
Ранг: 233
19.09.2006 // 13:55:41
ident пишет:
Принципиально нужно решить один вопрос - где будет происходить собственно анализ.
Если дело спешное, лЮЮди в опасности и т.д., то вариант с консервацией проб(патронов) и дальнейщий анализ их в стационарной лаборатории с ГХ/МС видится несколько "неоперативным". Лююююди к этому моменту могут и кедами щелкнуть.
Есть переносной ГХ Agilent 3000, который оснащается достаточно простеньким, но эффективным термодесорбером. Время анализа конечно варьируется, но в среднем анализ вместе с сорбцией-десорбцией занимает 7-10 минут. Ящик весит около 15 кг, есть варианты установки на тележку. Можно даже квадрупольный МСД Agilent 5975 к нему прикрутить и использовать как табуретку в передвижной лаборатории. Но на мой взгляд он там не нужен. Хотя если денег есть, то чего б не купить.
Стоит портативный ГХ+термодесорбер не больше 75-80 kUSD. Точный цифири можно уточнить у Д. Пронькина pronkin{coбaчkа}interlab.ru www.interlab.ru
ident
Ранг: 160
19.09.2006 // 14:25:44
EX-Mnemonick пишет:
Абсолютно согласен. И уже связался на эту тему.
Спасибо за ссылку.
Dmitryus
Ранг: 417
19.09.2006 // 14:37:11
Хромасс штука хорошая, конечно-но лично мне почему-то не верится в эффективность сего проекта.Лет несколько назад после Гурьянова некие ребята тоже выдвигали аналогичный проект, но все свелось к банальному освоению средств.
Думаю, специально обученный собачонок гораздо эффективнее. Да и работать с ним приятнее-можно поговорить, они хорошо слушать умеют.)
19.09.2006 // 14:43:26
Dmitryus пишет:
Поддерживаю!
Нос собаки в среднем чувствительней человеческого в 50 раз. И способен уловить например масляную кислоту (один из основных компонентов человеческого пота) на уровне менее 0,1 мкг/куб.м
Никакой хроматограф не сможет обеспечить такую чувствительность и самое главное - надежность идентификации.
А стоит суперпородистый щенок, скажем добермана около килобакса, еще две тонны баксов нужно чтобы вырастить и обучить. Все дешевле, чем портативный хроматограф.
ident
Ранг: 160
19.09.2006 // 16:19:46
Попытка - не пытка. Тем более, что покупать-то на данный момент ничего не требуется. А времени на это потратить не жалко.
