МС/МС: разные соотношения интенсивностей по двум переходам (MRM) в образцах >>>
лад Пользователь Ранг: 91 |
а вот и абстракт статьи.Detection of PPARδ agonists GW1516 and GW0742 and their metabolites in human urine. Tim Sobolevsky, Marina Dikunets, Irina Sukhanova, Edward Virus, Grigory Rodchenkov Moscow Antidoping Centre, 105005, Moscow, Elizavetinsky per. 10, Russia. sobolevsky{coбaчkа}dopingtest.ru. Peroxisome proliferator-activated receptor-δ (PPARδ agonists are the drug candidates with potential performance-enhancing properties, and therefore their illegitimate use in sports should be controlled. To simulate the metabolism of PPARδ agonist GW0742, in vitro reactions were performed which demonstrated that the main metabolic pathway is oxidation of the acyclic divalent sulfur to give the respective sulfoxide and sulfone. After being characterized by liquid chromatography-mass spectrometry (LC-MS), these metabolites were evaluated in urine samples collected after a controlled excretion study. For comparative purposes, GW1516 excretion study was also performed. It has been shown that GW1516 and GW0742 are best monitored as the sulfone metabolites which are detectable in urine using LC-MS/MS based procedure up to 40 and 20 days after a single oral dose of 15 mg each, respectively. The unmetabolized compounds are measurable only for a short period of time and at low ng/ml level. The sulfoxide-to-sulfone ratio for both GW1516 and GW0742 changed irregularly in the range of 1:3 to 1:15 depending on time elapsed after administration with a tendency of increasing the ratio with time. The other important finding was that the abundance of GW0742 and its metabolites in urine is about ten times lower than in case of GW1516. Copyright© 2012 John Wiley & Sons, Ltd. Keywords: ppar; ppar agonist; urine; metabolite; agonist; human urine; sulfone; their metabolite; excretion; detection; sulfone metabolite; performance-enhancing; illegitimate; peroxisome; sport; |
Дмитрий (anchem.ru) Администратор Модератор форума Ранг: 4491 |
Редактировано 2 раз(а) Spectrometrist, согласен в общем случае ![]() но мало информации. Хотя самого напрягают близкие переходы. Structure of GW1516 Ссылка на абстракт: |
Spectrometrist Пользователь Ранг: 777 |
Редактировано 1 раз(а) ни и зачем это сюда постить? Не засоряйте форум, плз Это относится к постингу лад 15.02.2013 // 15:44:03 |
В итоге имеем - это два протокола на два разных вещества (пусть и связанных между собой). Конечно всего 2 перехода в близких массах напрягают. лад, вам то что нужно? |
virtu VIP Member Ранг: 2136 |
Методики разные. CE, в частности. |
эти листы А и Б это не из статьи.это уже заключение анализа мочи. спасибо . есть еще мнения. |
Редактировано 1 раз(а) прочитал статью, снялся вопрос про близкие массы. У них на это орбитрэп. лад, а описание эксперимента (оборудование и тп) нету? Что еще есть кроме страницы на пункте 4.7?
вы не правы.вещество одно GW1516.ОНО КАК УТВЕРЖДАЮТ АВТОРЫ имеет 2 метаболита. 1.сульфоксид 2.сульфон. в первом и во втором заключении они говорят что обнаружен сульфон. |
тогда не понял - а как же они делают MRM? Откуда эти переходы? Извините, нет времени статью читать сейчас, сам сижу отбиваюсь от ревьюеров, очень злые попались -
лад, и ЭТО тоже у Вас? что же вы ели то? все подряд?
Ответов в этой теме: 98
